Location of brakelight switch? Gears stuck
Peter Michaels
Cleethorpes
2008 C-Class 180 SE Kompressor 1.8 Saloon
Thank you for any help in advance
Vehicle 2002 C Class T wagon 220 CDI Avantgarde diesel. KN52ZPD
Gears stuck in second gear during driving
When car is stationary it only gets from Driving position into neutral
That is with the engine running.
When I switch the engine of and then on again I can move gearstick up and down. But then after driving same thing again.
My mechanic suggested its the brake light switch.
So I bought one and he thought it should be above the brake pedal.
But he can not find it. He suggested that Mercedes might have moved the location of it to somewhere else?
Also i found out that there are two different
brake light switches for this model car, both have 4 pins.
Please help, this car drives me nuts, there is something different wrong every week.
Have you had the error codes read?
Have you checked the ATF level?
As above you need your codes read, could be gear selector and/or gearbox electrics pack.
I won't be your brake light switch.
