gazza9911
I have problem with the boot on a 2001 merc clk 320.
Everything was ok until last night when I went to get the shopping out (inc freezer stuff (& bag of ice)).
The boot will not open either with the key fob (it opens/locks the front doors and fuel flap ok) nor the interior remote switch (nothing at all there). Boot lock seized up (I did get metal (insert) key fully into lock but unable to turn - WD 40 sprayed fully into lock with red tube). I replaced the fuse under the bonnet (no. 7 - it didn't look blown but changed it anyway!). Rear seats in locked position.
Everything else on car works fine!
I searched the net and found that access could be gained through the first aid box, releasing the rear seats. This done, I got the shopping out.
TO THE PROBLEM !!!
I need to get the boot lid unlocked. (Can I unlock it from inside the boot?)
My Thoughts -- Possible fuse in boot - Please don't say use key in boot lock as like I say this is totaly stuck solid.
Thanks Gary
TO THE PROBLEM !!!
Thanks Gary
