On the basis that there is no point carrying a spare wheel if you can't undo the wheel bolts with the tools carried in the car, I decided to remove all the wheel nuts and tighten them again at something less than gorilla tight. Managed all of the normal wheel bolts and one of the locking bolts. The other 3 are so tight I decided a strategic withdrawal and some thought was needed before the locking bolt key got damaged.
In terms of the locking key surviving intact would it be safer to get a garage to undo them with a rattle gun ?
Any thoughts on whether the threads should be dry or lubricated in order to prevent future problems ?
I've always greased wheel bolts and never had a wheel fall off in 40 years.
