chesterpiglet
- Oct 8, 2008
- Mercedes W211 E280 Cdi Sport Estate
Hi all.
Had a puncture so have the temporary on. It took a 2m scaffolding pole & all my weight(100kg) behind it to remove the nuts. It's going into a Renault Dealership on Tuesday to have new tyres all around(supplied by me)- fitted & balanced for €60(reasonable for France). So this morning I have checked all the others(loosened them all off, cleaned & greased up) & found just one locking bolt- on opening my bolt key box I was greeted by this(nice of the garage to tell me). The part number on the box does not correspond to the type of key I have(good job I checked). Went online to find possible solutions, the most effective(other than buying a new key of course) being hitting a slightly oversize socket onto the bolt & removing like that. Looks easy on the videos but I need at least a 22mm socket to do this.......... which of course won't fit in the wheel nut aperture! You can see from the photo how the "garage" removed it before by removing the outer collar & then hammering on the socket. I'm loathe to buy another key as I wont be using the locking bolts again. Eventually...... my question is how difficult is removing this collar? I guess on a ramp with the right tools quite easy but probably not for me(in the garden with a dodgy hip) so I've answered my own question really. "having a go" will mean a new key wouldn't work & the Renault dealer may have their own solution to easily removing it. The 4 remaining nuts on this wheel weren't as tight as the others either so the key would probably have worked on it. So yet another thread on breaking locking wheel nuts............ take them off! If only I could............
