London Bus Drivers - Dangerous.
if you are caught in a crash next to a bus pulling out of a bus stop you will be automatically at fault.
Erm , no : buses are subject to the same set of rules as all other road users .
There may be little 'please give way to this bus' stickers , and a 'rule' which really is only ADVICE in the Highway Code , but legally these count for little .
The onus is still on bus drivers or any other driver to ensure that it is safe to move off before doing so . However , I agree there are good and bad bus drivers , as with all other classes of road user , so caution is the watchword .
The use of trafficators has little bearing on the matter either : completely unnecessary if no deviation in course is required to pass the bus ( eg if it is in a bus layby and you continue straight past ) , of dubious use to following drivers as an early course makes it obvious what you are doing , and inappropriate for oncoming traffic to which you would have to give way and wait for to pass first if insufficient room to pass .
The only 'signal' appropriate when passing a bus is a horn warning for the benefit of disembarked passengers who might be about to step out from behind the front end of the bus into your path ( but consider the possibility of a deaf passenger or a youngster with an iPod who may not hear you ) ; a headlamp flash , whilst technically correct to advise the driver of your presence , will often be misinterpreted as a 'please pull out in front of me' gesture and so would be dangerous .
At the same time , the above is not a licence to barge on regardless - a little courtesy and common sense goes a long way , as does good observation : when approaching a bus , if you can see that all the passengers have got on you can anticipate the bus will be moving off ; similarly , if when following a bus you see passengers getting up , you can anticipate the bus is going to stop and back off so you don;t get stuck behind it .
There are rules & rules, & regardless of what the Highway Code states, the particular rule - local, unwritten, call it what you like - that applies to London buses is that if you signal 99% of the time they'll wait & let you go past & if you don't signal 99% of the time they'll pull out, even if you are literally on top of them.
Since not everyone driving in London on any given day is FROM London and neither aware of their local 'unwritten rules' nor telepathic , it is time this practice was stamped out then .
A few sackings would do the trick , word spreads quickly .
Without wishing to get into a row with you, the advice you gave in post 41 will likely result in at least an argument with a bus driver & possibly a near miss or collision. As I said in post 42, if you signal 99% of the time they'll wait & let you go past & if you don't signal 99% of the time they'll pull out. Do it your way & you'll probably end up with a knock for knock (at best!) accident. They interpret 'the bus has priority' literally.
I won't give advice to people about the protocol or accepted method of passing sheep on a country road because I haven't been dealing with that on a regular basis for years & years. I do have considerable experience & local knowledge dealing with London buses without incident for years & years.
Ahhhhh-Bus drivers, black cab drivers, and tatty things that pass MOTs and are called taxis(how?).....all as bad as each other. The last time a bus driver did the obligatory pulling out on me whilst I was level with him, I just stopped-he punched the side of my work van (no it wasn't white at the time) , I got out as he was insisting in a verbally abusive manner that I didn't take note of the 'Please let the bus go first' sticker on the back of his bus. I told him that was all very well, and I'm more than happy to let the bus go first, if I am given more than a nano second to apply my brakes in a safe manner and allow him to continue with his intended manoeuvre and that the Highway Code was obviously omitted when he took his test. It was a no win situation where I was obviously right (even if I wasn't...I WAS:D) and he THOUGHT he was right, so after calling him a fat person whom slides his hand rigorously up and down his body part that only men have I thought the best cause of action was to retie both of my shoe laces in front of his bus, slowly, whilst enjoying a recital of poetic swearing on his part.
Neil , I have no wish to get into an argument either .
While I don't dispute that what you say may well be common practice in London , and even well known to locals , it still does not change the LEGAL position I outlined above .
My point is that local practices will not be known to 'out of towners' and , for that reason , any aggressive driving on the part of bus drivers should be stamped out .
The only other place I am aware of where this is prevalent is Edinburgh - the common factor with London being that they also had to endure 'professor' David Begg until he was kicked out of both cities ( now , I understand , inflicting his wacky transport policies on the unfortunate people of Aberdeen ? ) .
I did advocate the use of common sense and caution in my original post and have to say that I have driven in London on numerous occasions in recent years without incident .
Derek,
I wholeheartedly agree that aggressive bus driving should be stamped out but don't hold out much hope. London is an overcrowded nightmare to drive in (& live in IMHO) & pushy, aggressive, rude, inconsiderate driving is commonplace, not just amongst bus drivers.
I think our disagreement is due to differing knowledge of local conditions.
Very nearly all of London was built before before buses & cars came into common use. Garages & even driveways are rare & nearly everybody parks in the street. Victorian residential roads designed with lots of pedestrians, children using them as play areas & an occasional horse & cart in mind are now parked up nose to tail on both sides where bus stops are a roughly 15-20 metre clear space amongst the parked cars. Until you get out in the suburbs, maybe 10-12 miles from C. London there are very, very few bus stops that incorporate a lay bye. There just isn't the space & nearly all buses stop at the side of the road, not off it in a lay bye.
In these situations where 98% of the time the bus is at least partially blocking the road the use of indicators is essential as it gives the bus driver fair warning you are coming by & drops the cloak of invisibility cars seem to have for bus drivers. Where there is a proper off road lay bye normal rules on pulling out into traffic apply & are largely obeyed by drivers of cars & buses alike. It's only at the bus stop at the side of the road that one encounters the kamikaze 'pull out without a care' bus driver. TBH, I do have some sympathy for them. Few motorists want to be stuck behind a bus & rarely let them out. The bus driver's actions are born of necessity.
I've noticed a recent-ish trend where it is now the practice of some bus drivers to deliberately pull up & park several feet away from the kerb to block the road & traffic behind them so they can pull away from the bus stop unimpeded. While annoying I guess it does do away with the need to make a decision on anybody's part.
