As title,
I am not sure the wheels are genuines but they are 5 studs , 16" and said PCD 112? Is that the centre / hub?
Would that fit an E300TD?
Cheers.
Olivier
The term PCD stands for (pitch circle diameter) and is the diameter of a circle drawn through the centre of your wheels bolt holes. PCD is measured in millimetres and also indicates the number of studs or bolts the wheel will have.
One of the most common fitment has 4 studs and a PCD of 100mm, hence the fitment 4x100.
from the chart those will not fit then: The alloys are fitted with Continental 225/60 R15 The markings on the inside of the rim is ET 25 - PC0112 - TSW - 6J10 - 30943
As Dash has said the wheels are actually 15s. The R15, on the tyre gives the answer. Someone has measured the outside edge of the wheel, which is incorrect.
Sorry, my miss explaining.
The first set I don't know yet.
But there was this other set below eBay - The UK's Online Marketplace
that I was lloking at and used the chart and its not in to it for the w210.
they are indeed 15".
the first one are 16", but nothing about the ET yet.
Anyone selling a set of rim by any chance? I would even be really happy with some cheap steel rims, it for winter tyres. The road here are a nightmare and my 18" rim are too dear to get winter tyres
Cheers.
Where about are you? A wee far away are you?
Do you have any steel rim?
At the moment I just do some window shopping as there is no money, but I keep those in mind, this is a good deal with the tyre, but I was thinking of getting winter tyre as mine are only 5000 miles on at the moment, this is why.
Cheers.
Olivier
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
