Jan 24, 2011 #1 R rong New Member Joined Jan 24, 2011 Messages 3 Car ml 270 mecedes hi all new to this club looking for some help.i have 2002 ml270cdi and looking to fit a reversing senser But do not know which color wire going to the reversing light to use, any one know please
Jan 24, 2011 #2 BlackC55 Authorised Forum Sponsor SUPPORTER Joined Feb 8, 2007 Messages 20,783 Location Portsmouth, Hampshire. Car E55K SL500 E250X2 Smart44 Brabus Track car E450Cabriolet X350 Pick up Just pop it in reverse with the ignition on and no other lights switched on and whatever wire has 12V on it is the reverse light.
Jan 24, 2011 #3 OP OP R rong New Member Joined Jan 24, 2011 Messages 3 Car ml 270 mecedes BlackC55 said: Just pop it in reverse with the ignition on and no other lights switched on and whatever wire has 12V on it is the reverse light. Click to expand... hi thanks there is no wire exposed so can this be done without removing any wire plastic casing,hence why i was asking about color codes thanks ron
Jan 24, 2011 #4 stchris356 New Member Joined Dec 8, 2010 Messages 20 Location Warwick Car W211 E500 Remove the connector to the lamp cluster and using a test light or volt meter probe the connections on the plug to identify which is the correct wire!
