Markturner
Hello, im new to this group but I'm hoping to find the answer to an on going issue my local independent cant fix..
I have a 2009 S320 cdi, all was fine until the gears once the engine is warm go from 1st to second then to 4th. I can use the paddles to engage the others. Independent had the car for 2 days, checked ecu as it was in full limp mode, changed a rear wheel speed sensor and spent an extra hour on the wiring on the EGR. O2 sensor had been changed prior as had EGR and MAF unit. Cost me £550 and still not working once warmed up, when cold all is good????
