SVAMG
Hello all,
I hope you are all well. I am new to the forum and as a young owner I require advice from more experienced owners.
I drive a Diesel 2009 E220 with approximately 140,000 miles on the clock now. Bought the car in the February had quite a bit of work done to it since then. Will list if needed.
When I cold start the vehicle the engine is really loud and nearly holds 1,000 revs for approximately 4-6 seconds before quietening down and dropping down to 650/700 revs. It takes approximately 15-20 minutes to hit 60 degrees (coolant pump was replaced two months ago as there was a very slight leak) and then reach 80 degrees reasonably quick once I start to drive.
The car also feels a lot more sluggish now as opposed to before. I am not sure if this is down to the cold.
Any and all advice is greatly appreciated.
