Low Air Con Flow on 2006 R320CDi
jtotheb
Mercedes E350 Cab & GLE350 SUV
I'm getting a strange issue with the air con on my 2006 R Class.
Basically, although I get cold air, the air flow is very low and only really comes out at anything approaching a decent rate when I have the temp gauges set to the blue dot below 16 degrees. The flow rate also dramatically drops when I turn on the rear vents too.
Any ideas what this could be?
Thanks in advance
When were the last time the dust / combination filters where changed?
These can clog & reduce air flow as the air is being restricted.
Hmm, not sure. I had a B service about a year ago but not sure whether they were changed.
