Low airflow from dash air vents..
DABENZER
Rome, Italy
e320 w211 sw cdi v6
Hello again everyone,
Been using the wagon ever since i sorted out the suspension problems i had months back..
Another problem has raised it's horrid head now..
I'm not getting virtually any air output from the vents on the dash with the aircon on, with outside temps hitting 47 degrees, it's getting a bit unbearable now..
Any ideas on what has gone wrong here?
Just to recap, the car in question is a 2006 e320 w211 cdi sw model.
Cheers.
Check the filter under the bonnet
The pollon filter under the reserve battery? Brand new..
Tried the blower even without the filter, same thing, nearly no output..
Do you also have the filter behind the glovebox?
Hmm, That's a new one, i didn't even know there was one fitted there!
I'll have to check..
Cheers
yep, pollen filter change should do it. had same problem on my old CL a few years back.
+1 one for the above.
Also I recall a way to reset the AC but can't remember the exact procedure for it, I think you have to:
Turn key to position 2
Press and hold both the air recirculation and demist buttons until the leds flash.
The car will then test all the air vents while it resets the AC for a minute or two.
When they have stopped flashing remove the key wait a couple of minutes and start the car as normal.
It may have been in one of Killerhertz you tube vids I saw this.
