- Jul 12, 2011
- Location
- Near Salisbury
- MX5 1.8 Sport, Range Rover 5.0 SC, BMW X1
Just when I was thinking to myself yesterday that the car was running well it started to mis-behave this morning.
The first symptom was the engine turning over for longer than usual before firing, the starter was not labouring and the battery is fine, it just took a couple of seconds to fire.
One started all seemed fine until I went to pull away from a traffic island when it felt as if it was going to stall, this happened a few minutes later and although this has not happened since then the initial throttle response is not as crisp as normal. Also, I noticed that gear changes were initially a little hesitant.
Revving in neutral shows a slight mis-fire / hesitation at around 1200-1400 rpm but then it smooths out. No faults or warning lights are displayed.
I know a Star diagnostic is best but that is not possible until Friday at the earliest. My suspicion is a MAF issue, is there a way to test voltages at the MAF and if so where does one test and what range is normal?
Thanks.
Thanks.
