lower wishbone bushes kit question
That bolt is the anti-roll bar link bolt, not the main wishbone bolts.
This mean that you still need to buy new bolts or re-use what you can... But with all the rust there, might be of a little challange...
Odd for a "kit" not to included the major bolts?
Just re-use the ones you have.
Yup, That`s the one that requires the splined bit. And they can be tight.!!
Thanks. By splin thingy, you mean a torx, is it? I got that :)
Perhaps a MOD could merge this with the other threat as they seems to be merging together?
Cheers.
Olivier
Cheers.
Olivier
Yup, Torx T50 I think , but not sure. Deffo seen W210 new arms (with bushes) for the right side of £70 on fleabay.
I saw those too, when I said 150 it was for both.
Which is still 100 more then the bushes...But seems a lot less pain... ;)
and now witht he eurocar part, they are actually 120... humm...
