Lowering help!
babyblueCE
300 CE
Hello all, i have recently bought a 300 CE and it seems as if the pevious owner has installed 40mm lowering springs on the front and rear but i am sure that i have self levelling suspension on the rear. Does anyone know where i can buy a set of coilovers for the above or is there anyway of adjusting the self levelling suspension so it sits a little lower?
Dieselman
Banned
Peugeot 403 Convertible
You can adjust the self levelling by adjusting the link from the rear anti-roll bar, but I'd be surprised if your CE has it fitted.
kth286
Caversham Berks
E320 Coupe
do you have the fluid tank in the engine compartment for self level ?
OP
OP
babyblueCE
babyblueCE
300 CE
I havent checked that to be honest. I will have a look and let you know. The reason why i say that is because the car seems to be sitting lower at the front than at the rear. Is there anyway i can check if the rear has been lowered or was there a standard right height in mm i could just it against?
