zubear
- Oct 22, 2010
- E-Class Coupe
hey there has anyone had this done to your car and how is it like Mercedes E Class (W211) Lowering Kit / Module / Links on eBay (end time 29-Dec-10 20:03:12 GMT)
would you recommend buying them or get some rims first? because im thinking of getting some rims first and then see how much of a drop i need.
I have these on my cl, easy to fit, took an hour including adjusting them
I have a set of these for sale, had them on for a few months, good thing about mine is that they are set up already (adjusting height as a long process). I can fit them for you too.
and how much you after mate?
£50 takes them
I will ask my friend I'm not doing it! LOL
Maybe I was just lucky, I took off the old link on the front, made the adjustable ones slightly longer/shorter using the guide, made both the adjustable links the same size and put them on. Then did the same for rear. Then once on, you can leave one end of the link plugged in and adjust the other end if you need to adjust the height. £50 is a good price though.
