Lowering w205 estate
emc4raz
slough
c220 cdi sport coupe
HI All
Just bought a w205 estate se, I have just put 18" amg alloys, the car seems to be sitting a bit high, can I put AMG springs on the car
whitenemesis
MB Club Veteran
Lexus RC300h F-Sport 2019
Purely an optical illusion, presuming you have fitted the correct section tyres to the new rims. The wheel to arch gap is the same as on 17" rims
That said, not sure AMG spec springs would lower the car as it's already a sport variant. Plus one would ideally also have to fit the correct shocks to maintain ride quality.
OP
OP
E
emc4raz
slough
So my car is a se executive at the moment, I think they do sit a lot higher, was possibly think of getting a spring set of a amg spec car, do they have air suspension on the rear
Gazwould
Everywhere
S204 C250 CDI AMG Sport
Not optical , tyres aren't produced in the sizes stated !!
Plus sizing = plus rising .
The tyre to wheel arch gap is often reduced but the chassis is further off the ground .
markjay
MB Master
London
W204 C180 Executive SE 2013 Automatic / COMAND NTG4.7 and Morel speakers fitted by www.comand.co.uk
On the W204, the Executive SE suspension is softer and rides higher (allowing more spring travel) than the Sport and AMG Line models. I would imagine it is the same with the W205?
Also, I am assuming the OP is referring to fitting suspension component from the AMG-Line variant, and not from a C63 or C43?
If so, then I wouldn't just buy AMG-Line springs (and dampers), because I am not sure what other suspension differences are there between the Executive SE and the AMG-Line cars. I think a safer bet would be to buy and fit an after-market lowering kit made specifically for the W205 Executive SE.
Gazwould
Everywhere
Eibach Pro with Bilstein B4 dampers , but select the Sports suspension version.
renault12ts
MB Club Veteran
2005 W215 CL500.
I'm not sure what you mean. With respect, I think your statement is nonsense.
If you increase the diameter of the wheel you put on tyres that will maintain the diameter before the change...so plus sizing will not be plus rising...unless you get it wrong.
And, of course, if you put a greater diameter tyre on (thus reducing the gap between tyre and wheel arch), the car will be raised...that's a truism rather than an interesting fact.
Imagine the diameter I'd have when I changed from 17 to 19s!!! But no, with correct tyres they are a couple of mm out. And a couple of mm is insignificant since it is less than the difference between a new tyre and a worn tyre.
Gazwould
Everywhere
You get the correct size , but they are not because the tyres vary in size from manufacturer to manufacturer .
I love this one...
Gazwould
Everywhere
They manipulate ate what they want to do with the tyre , wider for grip and reduce for economy .
The lower profile tyres have built in comfort by being taller !
renault12ts
MB Club Veteran
2005 W215 CL500.
I'm confused...lower profile tyres are not taller than their higher profile equivalents.
Do you know what the profile ratio refers to?
renault12ts
MB Club Veteran
2005 W215 CL500.
HI All
There is an implied causality in your post.
For the elimination of doubt I read your statement as saying you've changed your wheels/tyres but still have the high look you don't like. You are not saying that the new wheels/tyres have had an affect on this, but you'd just like a lower car? If yes...then the AMG (OR AFTER MARKET) SPRINGS WOULD PROBABLY DO WHAT YOU WANT. i DON'T KNOW IF YOU HAVE SELF LEVELING SUSPENSION ON THE REAR LIKE THE e cLASS...BUT IF YOU DO, THIS CAN BE ADJUSTED TO LOWER THE BACK...BUT WHAT ABOUT THE FRONT?
Oops...sorry for the caps (can't be bothered to type that again).
Gazwould
Everywhere
The lower profile are taller than the actual aspect ratio math .
So these tyre calculators are only a rough guide .
OP
OP
E
emc4raz
slough
Yes its not made it higher but would look better slightly lower, its a basic spec so I don't think it has the self levelling suspension. I will try and post a pic l8r 2 day
renault12ts
MB Club Veteran
2005 W215 CL500.
That's a new one on me.
So if I lay my 17" spare on any of my 19s" they'd be different? And what about staggered...that would be awkward since different size tyres front and rear can render the cruise control inoperable?
Do you want to stop digging?
Gazwould
Everywhere
Welcome to the real world.
We never stop learning .
Not many people notice it or uncover it !
My suspicions began as I had gained chassis sill speed bump clearence on a low coilovered car .
Gazwould
Everywhere
I can see you're still struggling with this and find the concept of tyres are not produced to precise sizes difficult .
Like I say not many uncover it .
