Lowish Oil Pressure
mercyboy
Hi, My w123 1985 230e,s oil pressure reads about 2.3 out of the 3.0 when travelling at 60 mph, Is there a problem with the engine the engine sounds quiet and drives smooth, My other w123 230e (1984 model) has full 3.0 oil pressure but this engine is noisier, Is there a problem with my 1985 engine.
What's the mileage on each car and when did you last change the oil?? :confused:
Hi, I have just purchased the 1985 230e so have not changed the oil/filter yet mileage reads 97,000 miles, the 1984 has had regular oil/filter changes and the mileage reads 75,000 miles.
Theres your answer then, a change of oil and filter does wonders mate. :cool: :cool:
Thanks Brian, Will change Today.
At that speed, should def stay on 3. If not, you have problems, so see what the oil & filter does...
Jay
Changed oil and filter pressure back up to 3, Many thanks for your advice lads.
You are very welcome.
Another satisfied customer, that will be £100 please. :D :D :eek: :eek:
Brian, In line with current stealers prices you need to increase yours. Much too cheap for good advice :D
The £100 is in the post.
