RWP278
- Sep 10, 2017
- 1989 Merc 190, 2000 Seat Ibiza GTI, 2007 Vauxhall Zafira 2.2, VW LT 35
Hi there,
Apologies for kinda hijacking this forum, but my LT35 is pretty much a Sprinter in disguise! Sort of brothers.
So, to my issue......about 6 months ago, keen on keeping the maintenance up on my van, whilst changing the rear pads, i decided to do a fluid change as well. It didn't start too well as 2 of the bleed screws snapped in the near side rear caliper and the off side front caliper. So, had to buy and fit 2 new calipers. At the same time i fitted all 4 new flexi pipes (also fitted new front pads).
Now i'm all ready to start bleeding. I use a pressure system where a spare wheel @ 20 psi is pressurising the master cylinder. Seemed to get adequate fluid out and at an adequate rate from all 4 calipers. Test the pedal with engine running and it goes straight to the floor and this is how it has stayed ever since.
At no point has the master cylinder been dry.
I have bled the system countless times. No air bubbles ever come out.
There are no leaks, no damaged pipes.
All calipers have been removed and double checked for correct installation etc.
Since then i have also replaced
the servo (for a second hand known working unit),
master cylinder (brand new) and
load proportioning valve (brand new).
I have driven it a couple of times just along the road and the pedal does just go to the floor. There is a small bit of actual braking action right at the bottom of the pedal.
I'm getting absolutely desperate now as this has been going on for months. I've had a mate who used to work for VW commercial have a look and he couldn't find anything wrong. I'm positive its something really stupid.
It used to be my pride and joy but now it sits on axle stands gradually going green. Its affected my business massively to the point where i'm having to close it down. I do what i can at home but its not easy and i've fallen out with the neighbours now as sometimes i have the van, 4 cars and a trailer on the drive and 2 cars on the road. I'm a mobile body repairer/self taught mechanic.
I'm suffering from from depression and anxiety, have massive debts and my marriage is close to breaking down.
A man needs his van.
My next thought was to try and get hold of a brake fluid pressure tester to see how much pressure is getting through to each caliper. My mate was going to borrow one from VW but simply can't get hold of it at the moment. I popped into the local garage i take all my customers cars to for mot's to see if they have one, but they use the mot rollers for such cases. I spotted one on Ebay but they're £130 and that's money i just haven't got. Plus its one of those tools i'll use once in a blue moon. I'm struggling to justify it.
There's no way i can take it to a dealer or indy because a) i can't drive it and b) i haven't got the money.
So guys, can anyone give me any advice/suggestions please.
Thank you so much
Roger
PS - If you reply or ask a question it might take a while for me to reply, but i will!!
Thank you so much
Roger
