Luggage Cover Blind not unlocking 2018 c220d estate
Ianflying
Doncaster
Mercedes 220D estate AMG line 2018
Hi
The luggage cover blind on my 2018 c220d estate is not unlocking to take it out. The button on my right hand side is in the pressed down position but just won’t release
Thank you
I thought mine was stuck. While pressing on the unlock button give the cover housing a good tug towards you. That worked for me.
Hi Simon
Thanks, tried that already and think it is well stuck but cant see anywhere to release it other than break the dam thing or put up with it :mad:
Yep they are stubborn they don't just shoot out when you press the button. You ned to give it a good heave.
Its even had the rubber mallet on it mate
Thanks simon
Theirs literally no room. Do you know how i can find any info / pics to show how the release mechanism works
I assume your pulling from the rear? ie from the boot side. If you’ve got a thin scraper or pallet knife try easing that i between the cover and the plastic bracket. Maybe give the button area a dose of WD 40.
Thanks simon
A bit like opening yale lock with a credit card.
I've just realised, is it not connected to the back of the seats, what happens if you try and put the back seats down?
