gbjeppm
- Oct 31, 2006
- Location
- Surrey
- C207 E Coupe 350cdi, W166 ML 250 Cdi Sport, R171 SLK 350, Suzuki V Strom DL650
Ideas please:
My 560 SEC is lurching quite violently to the right under braking, the harder i brake the more it lurches. This afternoon on a test run, it even skidded/wheels locked up and ABS did not kick in (this was braking very hard at 60 mph).
It was doing this a little before, and I noticed that the passenger side front caliper was leaking slightly through the pistons. I had both front calipers professionaly refurbed 4 months ago.
Anyway I sent the weeping caliper away again,thinking that this was the problem, and got it back yesterday, all fully working pressure tested etc, and all good.
I fitted it this morning, bled the brakes, all running clear through the front bleed nipples. I did not bleed the back brakes.
Anyway after that, test drive, and symptoms as above.
Is there anything else that can cause this? I took the passenger side tie rod off a few weeks ago, as it was seized. And then have had a full wheel alignment, so I know that my measurements are good.
Could a malfitted tie rod cause this? I dont think so, It still feel its a brake issue.
Anyway, does anybody have any ideas?
