....but runs very smoothly up to that point. I've just redone the valve seals and have noticed now that all the plugs are in great condition (no more oiling up). Just dont know where to start as it feels like it is being starved of fuel - but experience has taught me that usually when you suspect fuel, it is invariably ignition.
I've replaced so many ignition parts though EXCEPT the rotor arm, which looked in ok condition.
Is there a simple, shade-tree way of checking fuel pressure? And also the ignition coil?
Here's what i have checked/replaced etc
New HT leads
New plugs
New fuel filter
3 new fuel injectors (after tested at garage)
New Air filter
New temp sensor
'New' OVP (but checked it also with a multi meter)
ALSO checked duty cycle which is about 50% at warm idol
Repaired (resoldered) fuel relay
Any advice appreciated
M, Beirut
New HT leads
New plugs
New fuel filter
New Air filter
New temp sensor
M, Beirut
