Benz in Brazil
Last night I noticed that the pressure gauge on my W124 dropped quite low once the motor had warmed up.
When cold, and in 'Drive' the marker sits at 1 when I press the accelerator it jumps to 3. However, when the motor's warm it drops to nearly 0 then, as per normal, jumps to 3.
I change the oil regularly, the last change was 7,000kms ago. I also changed the filter (Hengst). My car was serviced by a MB 'stealership' in Brasilia up to 86,000kms and is now showing 107,000kms so I doubt it's an issue with the motor itself.
Could it be something to do with the pressure sensor or something as daft as a fuse?
Regards from sunny Brazil
