hismajestics
I have swapped a M104 from E320 into a W114 Coupe. It was originally a non-ASR car and 5 speed manual.
Now I'm facing some problems with the engine not revving (max 1500rpm i guess) and having high idle. When idling it runs very smooth. Can this symptom be due to a disengaged cruise control? I took away the control unit and wiring harness. Any connections that needs a signal from this control unit?
I'm aware of the rev limiter at 4000rpm if the car does not get a vehicle speed signal. I feel my problem is of some other kind. Thanks.
/johannes
/johannes
