theres a turbo conversion .google it I'm sure you'll find itDrift202 said:Hi looking for the best way to get 350-400hp from my 300-24vTE, is turbo the only sensible way? A supercharger is easier.....with a standalone ecu can i ring much more out of it....Any thoughts?
Find a old e55 cheap and fit the engine in it .
You sure about pissing all over a 55 Nick ? That's a tall order!Niks said:Forget the old Mosselman and TT kits, they are old and chances of you finding complete kits will be a nightmare. Turbobandit is the way to go if you want to boost your 300-24. You can select the right turbo to give you boost from low rpm (very quick spool up) and produce between 350-500bhp depending on how you set up it up. His kits are tried and tested and extremely reliable, plus with the standalone Megasquirt ECU's, you'll get much better mpg as a daily driver and further tuning capabilities compared to any of the Mosselman or TT conversions could ever give. E55 M113 - big money and lots of chassis modifications (i.e. steering box to rack & pinion conversion so the manifold clear the steering box). The sump needs to be modified to clear the ARB. The ECU needs to be recoded and modified to work without the ABS data otherwise it'll keep going into limp mode. It can be done but its a lot of money. For that money, Turbobandit's kit will piss all over the C43/E55/C63. PM if you want more details.
Niks, what sort of money are you talking about with the Turbobandit kits, would you get a totally driveable 400BHP for £4k all in?
I have seen them drifting their c36 and wasn't impressed by the way it drifted...but that's only my opinion.
It could be done if your doing all the work and tuning yourself keeping many other parts standard. His full kits start from about £8k upwards but that includes literally everything right from custom built parts (i.e. downpipes, exhaust, gearbox rebuild & strengthening, rear diff work, cooling system, Megasquirt ECU setup and tuning including the Maps he has programmed...basically everything else no one ever talks or considers apart from just Turbo's and Manifolds. Hence why he's kits are very reliable and can produce big numbers all day and night.
He's 980bhp W124 is his daily driver, drives like normal until you open it up. Again, its how the car has been setup and tuned. He's just gone over the 1000hp mark with a new aggressive cam setup
I have a TT kit, but it's for a M103.
I'm sure someone with an M103 will be after it
The m104 in 3.6 form the tolerances are very little ,the gap between cylinders is minimal and also has a water jacket so I'm not surprised he had nothing but trouble . Sent from my iPhone using MBClub UKNiks said:One of his guys who works in his garage has a 600bhp M103 running a TB60 Turbo.. he managed to beat a C63 coupe in a drag. It could be done if your doing all the work and tuning yourself keeping many other parts standard. His full kits start from about £8k upwards but that includes literally everything right from custom built parts (i.e. downpipes, exhaust, gearbox rebuild & strengthening, rear diff work, cooling system, Megasquirt ECU setup and tuning including the Maps he has programmed...basically everything else no one ever talks or considers apart from just Turbo's and Manifolds. Hence why he's kits are very reliable and can produce big numbers all day and night. He's 980bhp W124 is his daily driver, drives like normal until you open it up. Again, its how the car has been setup and tuned. He's just gone over the 1000hp mark with a new aggressive cam setup That white C36 wasn't Turbobandits, it was a guy who called himself Drift Loco. That 3.6 engine was a nightmare from the beginning but that dude kept going at it until he ran out of money.
