M113 E55 ECU map needed
JulianFDRacing
Manchester
S211 E320 CDI, BMW E36 323i Touring, Vauxhall FD VX4/90 (98 W210 E55 Running gear)
Hi All, I fried my 98 E55 M113 ECU, I bought an E430 ECU with the same part number and swapped over the DAS chip (square one) not knowing I needed to move the EPROM with the map on it. Now I have an ECU that passes the DAS and will crank the engine but it thinks its an E430. Has anyone read the map from a E55 that I could use to reprogram my new ECU. I have a working Galetto so was able to read the E430 map earlier but really need an E55 map to write back to it. My project is getting close to test driving so really would like the engine to run as it should
