Hi all, I’ve been in the process of fixing a rather bad oil leak coming from a sealing “bung” at the front on the V directly below the inlet manifold
Manifold was removed and bung removed and nee one installed (eventually).....
All going well so far.
All parts were ordered so went to start doing the few little jobs yesterday before refitting the manifold like changing all the breather pipes and vacuum hoses..
This is where the has hit the fan.....
The front hose coming from the bottom of the manifold up to the changeover diaphragm was brittle and in bad nick so I went to pull it off to change it........... BIG MISTAKE
IT goes through a rather weird grommet type thing which acts as a seal for the manifold which is meant to unavailable as a separate part.......
Anyone ever thought of a work around for this issue??????
HELP HELP HELP
HELP HELP HELP
