M113K Forged Pistons Arrived today
ACID
Birmingham
C63 Black Series , Mclaren 720s , 992 Turbo S , E63 W213
The Weistec Engineering M113K Forged Pistons were designed and manufactured to address the weaknesses of the OEM M113K pistons.
Our 2618-T61 forged pistons feature larger ring lands, improved piston dish, skirts, and wristpin mounting while still weighing less than the OEM pistons. Stronger yet lighter 9310 Steel Wrist Pins are included with our forged pistons. Our wrist pins are compatible with the OEM rods as well as any aftermarket rod that is made to OEM dimensions. High quality piston rings designed for the heavy boost that a built M113K engine will experience are included as well.
Each piston comes with ceramic coating on the piston top for added heat resistance and Teflon coating on the skirts to reduce friction. All the key design features of our M113K Forged Pistons come together to result in an engine that can handle high power levels as well as rev more freely and efficiently thanks to significant weight savings on the rotating assembly.
Key Features:
Maintains Factory Compression Ratio
2618-T61 Forging
Ceramic Coated Piston Tops
Teflon Coated Piston Skirts
Improved Wrist Pin Material and Design
Significant Weight Savings Totaling 101.5 Grams
Compatible with OEM and OEM Sized Connecting Rods
Performance Ring Set Included
High Strength/Quality Design and Construction
Increased Power Capacity and Heat Dissipation
