M156/M157 Cold Start Roar
developer
Volvo XC90 T8 Polestar c500bhp
Ok, AMG anoraks on.
A few of us have commented that whilst the M156 exhaust note is louder/fuller than the biturbo, at cold start our M157's seems even louder than the M156 at cold start.
Here's why, from:
William Vetter
Asst. Product Manager - AMG & Black Series
Exclusive Vehicles
Mercedes-Benz USA
It is all in the engine ignition timing and fuel delivery...
When you first start up the vehicle, the primary objectives are to get oil flowing and heat generating both in the engine and more importantly in the catalytic converter...
So when the engine first starts it is running far more fuel into the engine than would be needed when the engine starts warm...as well the timing retards so that combustion is incomplete in the cylinders...the net result is that this unburned fuel (or still burning fuel) is sent out into the exhaust and down into the catalytic converter where it quickly heats up the cat...
this change in timing and fuel load are why there is a different exhaust note...
after a short bit there is a good fuel load in the cat and the heat is building, it returns the timing to normal and reduces the fuel load...
for the folks that have the M157 engine, this start up exhaust note is far more pronounced....the goal of cat heat is the same but noise change is for a different reason...the reason is that a M157 engine on cold start is actually making the exhaust gasses bypass the turbo which makes the note much more pronounced...one the heat starts in the cat, it then closes the bypass and you can actually hear the turbo spool up and then the exhaust gets much quieter...
Now you know :thumb:.
Nice write up there, and logical I suppose if you think about it. Seen the little valve things on the turbos but never realised or even thought about what they did.
I know that mine is louder than most on cold start, especially when it's in the garage at home, though after a few seconds it calms down to a respectable level. In fact I remember bringing Acid's C63 home and it wasn't any louder than mine on the initial start up in the same garage.
None of those cat things to warm up on mine though so just a waste of fuel really. Fun though. :D
I should have made it clear that the non bold text refers to the M156 :thumb:.
Thanks John. we discussed this many times so its good to know that "two lions in a fight" wasn't a bad discription of the cold start noise on the M157 :thumb:
Very interesting John......and confirms it's not my imagination when I'm certain our GLE is louder on start up than even my SLS ever was.
