- Nov 6, 2007
- Location
- North Oxfordshire
- His - Denim Blue A220 AMG Line Premium / Hers - Obsidian Black R172 SLK55
Soon after purchasing my E63 I noticed that on start up there was a noticeable rattle from the top end of the engine for a few seconds. This would persist longest if started from stone cold, but was also present if started after the car had been idle for a few hours. It wasn't instantly noticeable from within the cabin, but was obvious if stood outside the vehicle.
A quick Google search turned up a relevant XENTRY document, published 16 June 2013, which had been posted on one of the USA forums.
Bottom line is that the issue is caused by the secondary timing chains rattling until sufficient oil pressure is built up in their tensioner systems. The fix is to install revised secondary timing chain tensioners and check-valves in their oil supply passages. This work has now been carried out under warranty on my car and it has resolved the problem.
Form the XENTRY document, M157 engines prior to 157 9xx 60 022333 (December 2012), M2768 engines prior to 276 8xx 30 001281 and M2769 engines prior to 276 9xx 30 406603 (February 2013) are affected.
