CraigHitchman
Hello,
I change my M271 engine in my C200 2008 Mercedes(W204) because it had skip timing and damage the valves. I now have in a similar M271 but with different engine number the first six numbers on this engine is 271948 and my original engine number is 271950. Now the car will start but when put in drive gear or reverse there is no pedal response however when in park the car has pedal response and will rev. Can you tell me what's causing this issue??
