Nadeemus
Hi members. I've just joined the forum, so here goes.
I have a 2012 W204 C180cgi automatic with intermittent acceleration issues. There is a light misfire and/or light hesitation under moderate/heavy acceleration but nothing I would call permanent loss of power and no problems under light acceleration. But the problem is that it is intermittent between start ups.
I have done the following:
Sparkplugs changed all 4
Ignition Coils changed all 4
Camshaft position sensors Both
Cleaned Throttle Body
3 Bottles of Injector Cleaner
None of which has worked. It is still happening and is still intermittent. The check engine light comes on and off by itself, but no codes.
There is occasional rough idle but no starting problems and no stalling ever.
Mercedes could not replicate the drive issues (intermittent) and my mechanic hasn't got a clue now, save for guessing. Please help. I've never had a car do this to me before.
PS
The car has had Timing Belt and Camshaft Gears about 6 months ago (OEM). This problem was present before then together with starting issues and startup noise which have all been fixed.
PS
