M272 E35 and E30 - Balance shaft diagnosis questions
Discussion in 'Engine' started by kenam, May 14, 2019.
  1. kenam
    kenam New Member
    25
    Apr 28, 2019
    UK
    Car:
    Avensis mk1
    Sorry to dig up an old thread - but having had a look at a few CLKs - I would like to know if you can guide me on deciding on taking a risk with M272 E30 or M272 E35 (As used in CLK280 or CLK350).
    From the complete M272 thread, I know how to check vin and engine number and there are 3 classes of issue (Balance shaft worn plastic cog, balance shaft solenoid and balance shaft solenoid leak).
    Issues 1 and 2 are more serious - but I don't really know how to asses the risk of catastrophic failure.
    As far as I can tell there is no way of knowing from a test drive (other than if the engine management light happens to come on).
    Specific Qs:
    - Can a engine management computer be plugged in to see the history or do the codes just get reset?
    - If it was repaired, what am I looking for in the service book?
    - What sort of mileage to failures start to happen?
    I am having to do a lot of remote research before looking at cars in person and want to make sure I am getting the right answers.
  2. Codger49
    Codger49 Hardcore MB Enthusiast
    1,687
    May 21, 2015
    South Kent
    Car:
    W209 CLK500, CLK280; W168 A190; E46 325i
    I always thought the worn balance shaft gear issue was down to improperly hardened (or not hardened at all) metal gears, and that the solenoids are all on the ends of the camshafts.
    The classic codes to show the gear issue are P0016 and P0017 at the same time. Very unlikely that any vendor aware of the issue would not have cleared them.
    Likewise for the solenoid issues, which from memory can be any one from P0010 to P0025. Solenoids are not a problem, around £20-25 each and all 4 are mounted at the top front of the engine and take only minutes to change. MB introduced an modified version around 2007 with an updated part number.
    The mileage for the wear issue can be anything, not all cars seem to suffer it and manner of driving will be a large factor.
    kenam likes this.
  3. OP
    OP
    kenam
    kenam New Member
    25
    Apr 28, 2019
    UK
    Car:
    Avensis mk1
    Ah ok, I picked up it was plastic.. but that doesn't really make sense (ie even the best plastic would be rubbish).
    But that is reassuring.. ie if it's the second issue with the solenoids, it's a case of wait for engine management light and 100£ tops plus labour? That's really just normal servicing price!
    With regards to the engine management codes, I didn't know if it was normal for the computer to keep a log of past codes or if it only shows current ones.
    Sent from my Moto G (5) using Tapatalk
  4. amazighman
    amazighman Hardcore MB Enthusiast
    237
    Apr 22, 2016
    Car:
    CLK 430
    German reliability ?
  5. Borys
    Borys Hardcore MB Enthusiast
    1,762
    Feb 16, 2011
    Nowe nad Wisla
    Car:
    2005 cl500
    You can check if car in question is affected via engine number - mercedes medic website describes the whole issue in detail. Also after 2nd part of 2007 that issue was no longer a concern, rectified. I had s350 from September and was free from it but I did check engine number before purchasing
    kenam likes this.
  6. OP
    OP
    kenam
    kenam New Member
    25
    Apr 28, 2019
    UK
    Car:
    Avensis mk1
    You can check the engine number (see opening post) and there are 3 issues - but as far as I know you can only check to see if the engine 'could' have the issue.
    Other factors like driving style and millage will make the issue more or less apparent (This is my understanding).
    My question is more "Assuming I test drive a car that I know is in the engine number ranges quoted, how can I tell if it likely to casue an actual issue".
    I think for the cog wheel (original issue) - there is no way of actually knowing without an impractical/expensive inspection of the cog.
  7. Codger49
    1,687
    May 21, 2015
    South Kent
    Car:
    There is a simpler check which involves inspecting the timing marks on the camshaft adjusters reluctor rings. This will only tell you if the timing is aligned (or not) at the time of inspection.
    This video refers to them (about 7 mins in):
    An indy I have used (Steve Garlick) once told me he came across more balance shaft issues in 350s rather than 280s and that chunks of rubber or plastic in the engine oil when it was drained often accompanied occurrences.
    None of which are of any real use when you are looking at a prospective purchase, hence most just avoid vehicles with engine numbers shown as at risk in the tech bulletin.
    kenam likes this.
  8. Borys
    1,762
    Feb 16, 2011
    Nowe nad Wisla
    Car:
    2005 cl500
    Only certain engines are affected
    As I had one trust me I went through all horror scenarios
    Just check engine number against given references on web.
    Even Mercedes themselves released article about m272 - issue was rectified later in production
    kenam likes this.
  9. OP
    OP
    kenam
    kenam New Member
    25
    Apr 28, 2019
    UK
    Car:
    Avensis mk1
    ye cheers all - I think I will avoid the real early ones and will consider taking a risk on one that has "only" the solenoid issue - since they can be done relatively cheaply (Or have I got that wrong as well?)
    Borys likes this.
  10. Codger49
    1,687
    May 21, 2015
    South Kent
    Car:
    No, that's about right.
    kenam likes this.
  11. PobodY
    PobodY Hardcore MB Enthusiast
    2,523
    Aug 23, 2016
    Stoke-on-Trent
    Car:
    CLK350 Sport, Nissan GTiR
    I don't want to think about it... o_O
    kenam and Codger49 like this.
  12. OP
    OP
    kenam
    kenam New Member
    25
    Apr 28, 2019
    UK
    Car:
    Avensis mk1
    I feel there is a story here lol.. and probably not one I want to hear!
  13. PobodY
    2,523
    Aug 23, 2016
    Stoke-on-Trent
    Car:
    Only that I've got the large M272 in the wrong engine range just waiting to give me a large repair bill.
  14. OP
    OP
    kenam
    kenam New Member
    25
    Apr 28, 2019
    UK
    Car:
    Avensis mk1
    Ouch - hopefully not!
    With the rarity of the CLK350 coupe my options are quite limited - There is a chance I will say f--k it and just go for the same and we can swap tales of misery and cry into our beer at some point in the future!
  15. clk208
    clk208 Hardcore MB Enthusiast
    1,115
    Feb 14, 2009
    NW
    Car:
    CLS
    Some independents were offering this repair a while back in the £1600 range inc parts and labour.
    Compare this to the cost to rectify any of the regular fails on many CDI engines MB and others- turbos, DPFs, injectors and it starts to look like not such a big deal.
    kenam likes this.
  16. OP
    OP
    kenam
    kenam New Member
    25
    Apr 28, 2019
    UK
    Car:
    Avensis mk1
    Out of interest - when you bought the 350 did you try out any of the smaller 280s? I'm wondering how much of a difference there is (I have yet to test drive a CLK280).
  17. anderoo
    anderoo Hardcore MB Enthusiast
    104
    Jun 21, 2016
    Car:
    C350 coupe
    I've spoken to the merc specialist garage I use about this, as my car is in the range. The first you'll know is a check engine light, there aren't any clues beforehand. Last time I checked the going rate for the repair was about £3k.
    I don't think the term 'catastrophic failure' is correct really, yes if the issue arises you'll need to get it fixed but the car doesn't just explode. I've read about people continuing to drive for many thousands of miles after the CEL lit up before fixing it. Not really recommended, but you get my point!
    My car is now on 90k miles and hasn't needed the repair yet. It probably will at some point, and if/when it does, £3k is still cheaper than buying a new car.
    kenam likes this.
  18. Codger49
    1,687
    May 21, 2015
    South Kent
    Car:
    For CLKs the difference is 40 bhp, 228 v 268.
    kenam likes this.
  19. OP
    OP
    kenam
    kenam New Member
    25
    Apr 28, 2019
    UK
    Car:
    Avensis mk1
    Sorry should have been clearer- how noticeable is 40bhp. How is the driving experience in the 280?
    I'd rather the 350, but due to issues finding them it might be quicker to get a 280.
Share This Page
