paulmackay
Wondering if any of you can help? I have a 2008 viano 3.5 petrol. It developed the issue where it couldnt read the cam sensors on the right bank. Balance shaft i hear you say...well stripped the engine down to a point of checking...balance shaft and vvt cogs seem ok...no visible wear....replaced the timing chain. In setting the timing...it is still out 5 degrees on the right bank...to get the markers to line up with the visual inspection holes and get them dead centre. Any suggestions or am i missing something on doing the timing...or is this an acceptable variable? Also am so close to giving up...ongoing for a long time...thought it might be easier just to replace the engine...do any of the other 272 fit the van or is it just the 979 variation? any knowledge and help appreciated. Thanks
