Hi all,
I have recently (3 days ago) bought a 2007 CL600 with the M275 biturbo V12. A couple of days ago I had an issue arise where the car would not start following a drive. After leaving it for about 10 minutes it started fine. Same issue happened again yesterday - drove for about 5 minutes just down the road. Parked up for a few minutes and when I got back into the car it would not start. About 15 minutes later it started and I made my way home.
At this point there wasn't an obvious check engine light (that stayed lit). Then comes this morning. It took several goes and about 10 minutes to get it started this morning - from cold. It did get going and I drove for about 20 minutes down the motorway to pickup a new Crankshaft Position Sensor (as I suspected this was the problem). At the parts place I was again stranded with a cranking engine. Eventually (after about 40 minutes) the car started - but this time with an illuminated orange engine light. I carried on home and parked up. Swapped out the crankshaft sensor and it started right up straight away. 2 minutes later and it's back to just cranking and not starting - so I'm guessing this isn't a CPS problem.
I have ordered an iCarsoft MB v2 reader so I can hopefully pull off the codes but want to diagnose as much as possible now before it arrives.
- I have pulled up the rear seats and can hear the pump humming on turning the key - and also while the car is cranking so I'm guess pump + relay are ok.
At this point I'm thinking it could be either an immobilizer issue (although the keyless entry/start seems to work fine). Potentially the camshaft position sensors. Coils (although the O/S coils were replaced 18 months ago) or the voltage transformer.
Despite all of this when the car starts and runs (and even when the engine light was illuminated this morning) runs and idles perfectly smoothly. No stutters, rumbles or anything. Pulls really well without any missing power or hesitation.
Any suggestions of what to check and how would be greatly appreciated. Thanks!
