designo500
Hi folks,
This seems to be a common problem affecting differant models. A/B class and C class etc.
My Wife has a 2006 B170, and the drivers door lock is doing the bouncing rat-tat-tat thing. The front pass door was done last year by Mercedes as a "good will" repair. It appears that good will has now run out, despite a FMBSH.
I've been advised that it needs a new actuator, bellows and some rivets to fix. I plan to try some silicone down the button shaft as a temporary fix. Not sure about rivet guns and door airbags etc!
It seems that the C,E, ML etc need a new spring rather than an actuator. Do they have a differant problem with the same symptom, or is there a common fix.
Any advice welcomed.
