- Jun 24, 2008
- Location
- London
- 2022 Hyundai IONIQ 5 RWD / 2016 Suzuki Vitara AWD
Not on a Mercedes.
Here are the spec for the O/p car.
Diameter...288
Thickness...25
Min Thickness...22
Height...47
Bore Diameter...67
Studs...5
Solid/Vented...vented
Just checked the ones for your old C124.
Diameter...284
Thickness...12
Min Thickness...10
Height...44
Bore Diameter...67
Studs...5
Solid/Vented...solid
Looks like proper brakes might have been a cost option...
And, as the disc should only be skimmed if it is is above the minimum thickness - usually around 0.5-0.6mm over the minimum - it seems that we are talking about a 'lip' of no more than around 2.5mm - a total for both sides of the disc (you can't just divide this by two - sometimes one side of the disc has a deeper 'lip' than the other).
