Maf Air Fl0w Meter
Gunny
Guisborough Cleveland
1999 CLK 320 elegance 2001 C200 Kompessor Avantgarde
Can anyone let me have the part number for a w203 C200 kompressor replacement MAF Airflow Meter.
Mine seems to have gone west - engine lacks power, fuel consumption is a bit heavy, looking on the website- classic symtems of MAF failure.
Gunny
Shude
Hardcore MB Enthusiast
Cheshire
CLK55 AMG
You'd need to provide a VIN, there are at least 2 different 200 kompressor engines for the W203.
OP
OP
G
Gunny
Maf
Vin No as follows
WDBD2030452F083273
Gunny
Shude
Cheshire
CLK55 AMG
Gunny said:
Vin No as follows
A1110940148 : AIR MASS SENSOR : EUR 321.17
btw I had a look at the datacard for your car and I'm impressed with the spec! It does however have one of the worst option codes I've ever seen on a car:
"026: discontinuation of spare key"
What's that all about? :confused:
I've PM'd the spec to you.
OP
OP
G
Gunny
Thanks for that - I took the car into a specialist in Middlesbrough yesterday, it seems the car had developed some faults in the ECU - NO NOT WHY, but they cleared them, the MAF readings are showing a bit low - its working but the readings are at the low end of the scale , i dont know if cleaning the sensor will help.
But the car is back torunning fine again - apart from the front end knock.
Ive no idea about the key - it came with a spare key though
ive Pm,d you back.
Gunny
silverarrow
do not clean send for recon at www.reman-bba.com or bosch agent on your maf is a mbz part and bosch also bosch part no on the sensor ie not the pastic case the sensor sits in £300 approx main agent £100 at bosch agent new recon they need to quote
