MAF cleaner
Eric Alex
ML270 yom 2000 and C230 yom2005
Whats the recommendation for MAF cleaner? I want to clean mine but not sure the best available cleaner to use
I mean MAF sensor for ML 270 CDI 2005
From what I have heard, cleaner will not cure the MAF issue, if that's what you have. Rarely do they fail due to a contaminant that can be cleaned off.
I over oiled a filter and clogged a master air flow up once, managed to clean it with a solvent terminal solution.
It's a spray on and leave to evaporate.
Cleaned mine up ok but it was only lightly soiled
If yours is at all damage rather than clogged then get a new one save yourself loads of trouble :thumb:
This is what it looked like after I cleaned it
Use throttle body cleaner. - It's designed to shift exactly the kind of muck that fouls the inlet pathway.
Hey guys thanks for all the info put the car in the star and realized i had lost the inlet valve so bought a new one at 160 dollars
