prprandall51
Hello experts, can you please help?
My car (211 E320 Cdi 2005) has gone into Limp Home mode (limited power, max 3000rpm, no kickdown, max speed approx 50mph).
From reading the many posts on this forum about these symptoms it appears the MAF sensor is most likely at fault (though it will need diagnostics to confirm - so this is not a definite diagnosis).
What I want to know is: is it worth taking it off and blowing it out with a compressed air cannister (as used to clean computer insides) to see if it works again, or is it most likely to need replacing (if it is indeed the MAF sensor).
I don't mind half an hour fiddling with it if it can genuinely be fixed with a clean out but I don't want it to fail again in a few thousand miles, either, possibly leaving me with a very long, slow journey home.
On the other hand, if a clean-out fixes it, I would rather that than book it into the garage and all that that involves.
Philip
Philip
