Mine was fitted near the drainplug. A point worth noteing, you do not need to remove the sump to do this. Attaching the magnet on the outside of the pan still works, providing the magnet is strong enough. An added advantage of this is, when your doing an oil drain, pull the magnet off as the oil in draining, and any metal particles will be released, and be drained out wth the oil. (In theory)Hi
I have bought a magnet for the sump of my 1998 210 auto box. Does anyone know is there a particular spot in the gearbox sump pan for placing it??
Thanks,
230K
