philsx
I have a W208 CLK cabrio and when I bought it a couple of months back I discovered that the main beam did not come on when the combination switch was pushed forward - though they would come on pulling it back to the 'flash' position. The supplying garage got a new combination switch from the nearest MB stealership and fitted it - and all was well ... for a while. But driving home from work yesterday the main beam suddenly stopped working - exactly the same symptoms as last time! I find it difficult to believe that the new switch has failed exactly the same way so quickly - has anyone any suggestions about what could be causing this problem? Is it possible that a relay somewhere may be faulty rather than the combination switch? (The car has Xenon dipped beams by the way but only regular H7 bulbs in the main beams.)
