MAIN CATS REMOVAL advice re sensors
Discussion in 'AMG Lounge' started by ray d, May 11, 2017.
  1. ray d
    ray d Active Member
    81
    Jul 4, 2012
    Northern Ireland
    Car:
    slk 55 amg
    Hi all I am sure this has been talked about before but I cant find anything but I am thinking of removing the main cats on slk 55 R172 but am not sure what will the sensors pick up and are they going to show up faults. Has anyone done this and had they any problems. Thanks
    Ray
  2. Cozy
    Cozy Active Member
    427
    Sep 22, 2014
    West Sussex
    Car:
    C63
    Hi Ray,
    I'm not a 55 owner but on my C63, I added long tube headers. Granted, these are catted but the cats are located where the OE secondary Cats were and there's nothing where the primary Cats used to be. Both pre-cat and post-cat sensors are plugged in but there's no Cat in between them. I ran a while like this without a tune and I never received any codes or rough running. Hopefully the 55 ECU works the same.
  3. brucemillar
    brucemillar MB Enthusiast
    8,663
    Nov 18, 2010
    Next Door to Alice - 25 'kin years now
    Car:
    C55 AMG Wagon - W124 300te 4matic Wagon - BMW 4.8is X5 E53 - SWB Pajero 3.5 V6 24v
    I think (I may be wrong here) that the ECU will just adapt to the new readings and not throw a code. But you may have to keep all sensors in situ (plugged into your empty pipes) or the ECU my complain that it can't find the sensors.
  4. PobodY
    PobodY MB Enthusiast
    2,523
    Aug 23, 2016
    Stoke-on-Trent
    Car:
    CLK350 Sport, Nissan GTiR
    I take it these are not lambda sensors then?
    No closed loop operation or fuelling adjustment without lambda sensors, but temperature probes the ECU generally couldn't care less about.
  5. grober
    grober MB Master
    27,846
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
  6. PobodY
    2,523
    Aug 23, 2016
    Stoke-on-Trent
    Car:
    So if you disconnect the front lambda sensors doesn't it throw a code, or does it just stop trying to run in closed loop?
    Obviously you don't need to have a catalytic convertor (legally you're supposed to have them for emission purposes, but the engine doesn't care either way because it's an exhaust thing), so the sensible suggestion would be to have a boss welded in to the new exhaust and screw them back in.
    1 person likes this.
  7. OP
    OP
    ray d
    ray d Active Member
    81
    Jul 4, 2012
    Northern Ireland
    Car:
    slk 55 amg
    So far that all sounds good. I bought a second hand set of down pipes to take the secondary cats out (which I have done) but against the wife's wishes there is still more "V8 sound" in there and I WANT IT. I will be able to put the original down pipes back and rear section in when car is in for service / warantee work and then for MOT (I had a custom made Power Flow system with Res out X pipe in and sports silencers at rear). Hopefully someone here has actually done the main cat removal which will confirm all the replies.The worst thing I done is took the Jag V 8 F type out on a test drive with the active exhaust system on it and I SO want the same noise as it just sounded soooooo good. Deep down I think the wife is hoping I get the sound I want and she can relax a bit more and bring the cheque back out of hiding :bannana:
  8. OP
    OP
    ray d
    ray d Active Member
    81
    Jul 4, 2012
    Northern Ireland
    Car:
    slk 55 amg
    Checked the links and I am afraid it all went over my head :dk: It would be great if someone who has done it could come in and say if it either worked or not. I will wait in hope
  9. daveenty
    daveenty MB Enthusiast
    3,425
    May 12, 2007
    NW UK
    Car:
    S63 Coupe
    If you remove both primary and secondary cats, the chances are that the car will throw P0420/P0430 codes, which are "Catalytic Converter Out of Threshold banks 1 & 2". This basically means that the downstream sensor cannot differentiate between the upstream one as the reading is too similar, i.e. the cat's not doing anything.
    There are a couple of ways round this. You can buy a spacer which theoretically removes the downstream sensor away from the flow, though I don't personally know anyone who has done this, or you can have the sensors mapped out via the ECU, which is how I got rid of my annoying CEL light. Any competent tuner should be able to sort this out for you.
  10. Alps
    Alps MB Enthusiast
    7,175
    Nov 29, 2002
    London\Essex
    Car:
    E55 2004 Silver, E63 Weistec AMG(SOLD), E55 2004 Silver(SOLD), C36 AMG 1997 (SOLD)
    as Dave says, you will need to map them out, not sure if they can be turned off in star also.
  11. OP
    OP
    ray d
    ray d Active Member
    81
    Jul 4, 2012
    Northern Ireland
    Car:
    slk 55 amg
    That is great I understand now, perhaps I would be best leaving it alone as it is still under warantee and I am pretty sure when it is in for service they put any updates in to the ecu so it might overwrite any mod. I was hoping that maybe the car might show up a fault but drive ok then I would put the cat pipe back in for service / warantee work
Share This Page
