Manual gearbox wont engage 2nd and reverse gears
Ianboid
Barnsley
Mercedes c220
The title says it all, 2011 mercedes c220 2.0d
Manual won't engage 2nd and reverse gears
Anyone have any clues ??
If it goes into first gear it’s unlikely to be clutch related so sounds as if it could be a selector pawl or at least something that might be sortable or reachable from within the cabin by accessing the top of the box
How do I get in to the box ?
If it is that, via the carpets and trim covering the gear stick. However, I’m wondering if you do much car work?
Will it select all the other gears without any abnormal resistance or nasty noises?
Is the gearstick in its usual position? Ie could an engine or gearbox mount have failed?
These manual boxes are normally pretty tough.
I've worked on cars before, just not a merc
