johnnybravo997
Hi guys
I have a w204, 220cdi, 2013, coupe
VIN - WDD2043022G130532
Engine management light has come one, I can not feel any noticeable difference to the vehicle when driving.
I read my codes
P010628 - ''the intake manifold pressure sensor has a malfunction. the signal is outside of the permissible range''
due to current UK lockdown, and losing my job, I am planning to try and fix this myself if I can!
I am trying to locate the MAP sensor, there seems to be 3 different sensors that could be a MAP sensor.
2 of them are quite easily reachable - used an electrical cleaner - (no luck)
1 sensor is a little more difficult to reach (on the right of the engine, about 30cm down.
part numbers are A0071530028 and A0101537228.
these are being referred to mainly as boost sensors, but sometimes as MAP sensors.
My question is - are boost sensors and MAP sensors the same thing?
any idea as to which one I should be changing? (i know this could be due to leaks etc, but I am just going to try and change the sensor first)
any help would be appreciated!!!
thanks guys
I read my codes
thanks guys
