So I have this cluster of 4 stone chips on the bonnet, which I am trying to hide.
The paint is called diamond white and it's pearlescent, but it is sort of semi transparent and the chips can still be seen through it.
I tried with a filler to hide them first, but after sanding it down to the same level as the rest of the bonnet the dark appears again.
I need to use something that will put a very thin layer and hide the, before using the touch up paint. Do you think THIS primer would work?
Here is a photo. Is the grey stuff some primer or is it the metal?
