Massive fire in London apartment block
Discussion in 'OT (OFF Topic) Forums' started by Steveml63, Jun 14, 2017.
  1. MancMike
    MancMike New Member
    0
    Jul 29, 2014
  2. Londonscottish
    Londonscottish Hardcore MB Enthusiast
    2,734
    May 12, 2007
    London
    Car:
    S212 E500
    They did. Endless complaints by the residents association plus a petition signed by 90% of residents over a string of concerns they had over fire prevention, fire containment & evacuation. All on record, sadly.
    1 person likes this.
  3. Druk
    Druk Administrator Staff Member
    5,309
    May 28, 2004
    Not far from Edinburgh.
    Car:
    2011 S212 E350CDi. 1981 R107 300TurboDiesel.
    Big hoo-ha about the lack of a central fire alarm, then someone knowledgeable explained that it was against perceived thinking to install fire alarms in tower blocks because someone burning toast (for instance) could set off the alarm and create a panic evacuation down an inadequate stairwell. It seems it's better to contain peeps inside their homes on the basis that the fire won't spread between apartments because of the type of construction.
    Of course, nobody thought of the fire spreading from the outside and it seems the recent fitting of UPVC windows allowed the fire to spread from the cladding into the inside.
  4. renault12ts
    renault12ts MB Club Veteran
    15,605
    Mar 5, 2009
    Car:
    2005 W215 CL500.
    The cause is obvious.
  5. Cymruambyth
    Cymruambyth Hardcore MB Enthusiast
    468
    Apr 9, 2017
    Car:
    Another one who doesn`t mindlessly swallow everything the press spoon feeds us?
    You`ll be saying man has been to the moon next :D
  6. KillerHERTZ
    KillerHERTZ Administrator Staff Member
    16,586
    May 21, 2003
    Cambridge
    Car:
    CLS63 AMG
    Until we have definitive facts its mere speculation.
  7. renault12ts
    15,605
    Mar 5, 2009
    Car:
    2005 W215 CL500.
    When the planes hit the twin towers it was obvious what had happened even before any official confirmation.
  8. markjay
    markjay MB Club Veteran
    21,959
    Jun 24, 2008
    London
    Car:
    W204 C180 Executive SE 2013 Automatic / COMAND NTG4.7 and Morel speakers fitted by www.comand.co.uk
    And yet... some still don't believe it to this day...
  9. KillerHERTZ
    16,586
    May 21, 2003
    Cambridge
    Car:
    CLS63 AMG
    Yes but the cause/reason for 911 wasnt obvious, which is exactly the case here. the only thing obvious is that a fire has occured.
    Im amazed how many people on here work for the Fire Service and are structural engineers.
    2 people like this.
  10. renault12ts
    15,605
    Mar 5, 2009
    Car:
    2005 W215 CL500.
    Two planes hit two towers...fire...collapse. Not obvious?
  11. ash59fifty-uk
    ash59fifty-uk Hardcore MB Enthusiast
    3,415
    Aug 9, 2015
    The shire
    Car:
    W204 C63, Ford Transit
    Build two tall towers out of Jenga blocks, throw two Airfix planes at both blocks hitting the top third of each structure
    Do both Jenga towers entirely collapse, or just the top third?
    :eek: :)
  12. Benzowner
    Benzowner Hardcore MB Enthusiast
    2,545
    Jun 21, 2004
    Bristol
    Car:
    B180 CDi W245 in Silver
    I am a retired FPO and worked on high rise apartments locally. Local authorities will not install a fire alarm system for fear of vandalism and false evacuation of the building probably leading to the system being switched off. Likewise they will not install a sprinkler system, as we all may know, set one bulb off and the lot will go off causing thousands if not millions of £s worth of damage. There is also the question of where to site the water storage tanks, the rooves are probably not capable of taking that sort of load.
    The strange thing is though, if you buy a property and convert to flats or bedsits, the local authority will insist on an alarm system which when activated will produce 85db of sound at the bed head, usually resulting in a sounder in each bedroom. Some of the flats in London were 4 bedroom.
    Unfortunately and by no way am I condoning it, it is risk assessment vs cost.
  13. ash59fifty-uk
    3,415
    Aug 9, 2015
    The shire
    Car:
    According to one of the tenants interviewed on the news earlier, they had no smoke detectors or audible alarms installed in the communal areas :(
    Shocking really, we have overseen many contracts where the specific work was to install fire extinguishers, smoke detectors, alarms, wall units and extinguisher floor cards to communal areas on all floors to thousands of buildings in London, a large majority of them being blocks
    Seems as though this building was behind the times
  14. renault12ts
    15,605
    Mar 5, 2009
    Car:
    2005 W215 CL500.
    Modern sprinkler systems surely are not all set off by one bulb?
  15. ash59fifty-uk
    3,415
    Aug 9, 2015
    The shire
    Car:
    Depends what type it is, some spray out foam and are far too easy to set off. As I unfortunately experienced in a plant room once, when I literally brushed past a particular low level installed sensor!
  16. poormansporsche
    poormansporsche Hardcore MB Enthusiast
    2,109
    Jul 1, 2010
    Car:
    W209
    Despite not owning a tin foil lined hat - I would suggest that the bottom line "cause" of this fire is the RBKC not wanting a concrete eyesore in the borough
  17. AnimMerc
    AnimMerc Hardcore MB Enthusiast
    218
    Jun 12, 2013
    East Riding of Yorkshire
    Car:
    Sprinter's
  18. Darrell
    Darrell Hardcore MB Enthusiast
    3,494
    Dec 15, 2006
    Back in Mill Hill but sometimes in Skiathos
    Car:
    A Jaaaaag, 2016 Dacia Duster and a 2004 Carrera (996)
    Benzowner,
    Regarding the tanks on the roof scenario. Isn't that why we have dry risers?
  19. grober
    grober MB Club Veteran
    26,140
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
  20. markjay
    21,959
    Jun 24, 2008
    London
    Car:
    From Wikipedia:
    'In January 2016, the Grenfell Action Group warned of the possibility that people would be trapped in the building if a fire broke out, citing the fact that the building had only one entrance and exit, and corridors that were allowed to be filled with rubbish, such as old mattresses.
    The Group frequently cited other fires in tower blocks when it warned of the hazards at Grenfell.'
Share This Page
