Massive fire in London apartment block
Discussion in 'OT (OFF Topic) Forums' started by Steveml63, Jun 14, 2017.
  1. Happytalk73
    Happytalk73 MB Club Veteran
    5,671
    Sep 10, 2015
    Uk
    Car:
    Vito
    Why not? I'd happily have them.
    We have a smoke alarms/heat detectors in all our bedrooms/living areas. Not a building control requirement, but it should be.
  2. geraldrobins
    geraldrobins Hardcore MB Enthusiast
    1,441
    Jan 26, 2013
    Car:
    VW Golf, past c200cdi
    Is it not a Part P requirement? I had to install additional detectors in habitable areas for a kitchen extension, not just in the kitchen. and Building Control requires Part P ?
  3. Happytalk73
    5,671
    Sep 10, 2015
    Uk
    Car:
    Vito
    No, not a requirement in EVERY room of the house. When constructing extensions all they ask is that new smokes and heat detectors are linked to existing.
    When we moved into our house it was 12 months old. Smoke alarm in hallway & heat detector in kitchen. I fitted one in every room (not bathrooms) so they're all linked together. IMO this should be a reg in all new builds. Smoke alarms will save lives. Excessive insulation will not. :wallbash:
  4. markjay
    markjay MB Club Veteran
    24,619
    Jun 24, 2008
    London
    Car:
    W204 C180 Executive SE 2013 Automatic / COMAND NTG4.7 and Morel speakers fitted by www.comand.co.uk
    When an existing building is inspected, findings might be classified as 'not to current standard', but not all 'not to current standard' findings require action.
    I.e., it is perfectly legal to have an existing building that does not meet regulations that would apply to a new build.
  5. Benzowner
    Benzowner Hardcore MB Enthusiast
    2,691
    Jun 21, 2004
    Bristol
    Car:
    Qashqai Acenta Premium 1.6Diesel
    What, have a sprinkler go off and then have to wait for the water to arrive? Dry risers are usually for firemen to attach hoses to outlets higher up the building, not too sure, but I believe many have been removed, back in the day, they installed copper dry risers about 4" diameter, many parts of them were being stolen :(
  6. Happytalk73
    5,671
    Sep 10, 2015
    Uk
    Car:
    Vito
    Agreed MJ. But once a complete refurb/renovation is undertaken the building should be brought up to current standards/regs.
    1 person likes this.
  7. ash59fifty-uk
    ash59fifty-uk Hardcore MB Enthusiast
    3,686
    Aug 9, 2015
    The shire
    Car:
    W204 C63, Ford Transit
    I've seen many still in situ, wether they are live though I couldn't say
  8. MancMike
    MancMike New Member
    0
    Jul 29, 2014
    No offence, but that's idiotic coming from you. How many fires come from outside? Statistics can't help in this case. It's unusual.
  9. MancMike
    MancMike New Member
    0
    Jul 29, 2014
    Come on Ant, I've set off smoke alarms unexpected when sanding, steaming, etc. If that destroyed all electronics in the house, I'd be displeased. It's just not a solution.
    Maybe if the only triggers were heat alarms rather than smoke but it's still not straight forward.
    Our 100 year old house has a central alarm system, if one alarm activates, they all sound. Similar to your new build.
    What happens in big commercial buildings is better. Like in the NCC where I work, there's a central alarm system. When there's a detection or alarm trigger, it sounds a warning "Staff call 33, etc", someone has to go to the panel and disarm it after investigating. If it's not cancelled, or is escalated, it turns into an evacuation message. It's pretty scary, but very effective. That'd work well in big blocks of flats who normally have a caretaker resident.
  10. Happytalk73
    5,671
    Sep 10, 2015
    Uk
    Car:
    Vito
    I'm just saying that the more technically advanced we become the more acceptable it be that we make steps to become safer. If there was a way to incorporate a sprinkler system into domestic properties then why not? Wouldn't bother me one bit.
    And if I've misunderstood your post and you're referring to a smoke alarm or heat sensor in every room then my house is fine with the concept. :dk:
  11. markjay
    24,619
    Jun 24, 2008
    London
    Car:
    Non taken.
    There's a list of things that (according to speculations) - while not have prevented the fire - would have been able to slow it done or at least give more people a better chance of survival.
    Sprinklers might have slowed down the fire from spearing internally as fast as it did;
    Working/loud fire alarms might have alerted residents earlier (many said that the alarm was not heard inside their flats);
    There are some reports that the dry riser did not work (in-situ hoses that the fire brigade would want to connect their hoses to in order to get water up the building fast);
    There are questions about the type of external cladding installed, as well as the insulation behind the cladding and dampers (materials intended to stop fire spreading between building components) being absent.
    All these factors caused the smoke and fire to spread more quickly that it would have otherwise done.
    All speculation at this stage, but the point is that if sprinklers and working fire alarms etc etc were in place the fire might not have been prevented but it is likely that less people would have died.
  12. dinoy
    dinoy Hardcore MB Enthusiast
    1,999
    Feb 15, 2010
    london
    Car:
    mercedes of course
    We have opened Al-Manaar Centre to be used as a temporary shelter for anyone affected by the fire...anyone means anyone of any faith or no faith. We'll also be providing emergency food and water as well as Iftar.
    Please help spread the above to our emergency services so that they are aware and can refer people to us.
    GrenfellTower fire - You can drop clothes, water or food to St Clements Church, 95 Sirdar Rd, W11 4EQ
    #GrenfellTower
    Feel free to share this post mchc.org.uk
    Both westway are also open for anyone affected . They can use the facilities .
    9 people like this.
  13. geraldrobins
    1,441
    Jan 26, 2013
    Car:
    Agreed I didnt say or mean all habitable areas. Before our extension I had a detector in the hallway but under part P I had to install one in the lounge as well as in the new kitchen and they are linked.
  14. renault12ts
    renault12ts MB Club Veteran
    15,959
    Mar 5, 2009
    Car:
    2005 W215 CL500.
    Unlike you and KH I know what happened.
    Sometimes things are so obvious we don't have to wait like sheep for the official report 2 years down the line. Action be taken immediately and the focus will be on the particular type of flammable cladding that we all have seen falling from the building...on fire.
    Why wait for a report...start making things safe now. The pity is this cladding was used after several instances where the same sort of fire had occurred. Dubai immediately came to mind when I saw the very first pictures...did you go into denial and think...no no no I must not judge?
    People need to wake up. Evacuate all such buildings now unless some kid with a lighter decides to do something awful.
  15. geraldrobins
    1,441
    Jan 26, 2013
    Car:
    What type of cladding was it then? Please enlighten us.
  16. grober
    grober MB Club Veteran
    27,624
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
  17. Darrell
    Darrell Hardcore MB Enthusiast
    3,911
    Dec 15, 2006
    Back in Mill Hill but sometimes in Skiathos
    Car:
    A Jaaaaag, 2016 Dacia Duster and a 2004 Carrera (996)
    Very flammable cladding.
  18. renault12ts
    15,959
    Mar 5, 2009
    Car:
    2005 W215 CL500.
    This type.
  19. renault12ts
    15,959
    Mar 5, 2009
    Car:
    2005 W215 CL500.
    Pontoneer, not having a go.
    I am aware that there is someone doing your job today who will have to photograph each and every corpse that will be discovered in Grenfell House. Not an easy nor palatable task.
  20. Pontoneer
    Pontoneer MB Club Veteran
    13,250
    Aug 19, 2002
    Ayrshire
    Car:
    '99 S320 W140 ; '93 300SL-24 R129
    Tanks on the roof are normally for either domestic water supply , or for sprinklers , which are a high pressure low volume system for tackling small , localised fires before they take a grip ; sprinklers won't extinguish a well developed fire . Sprinkler systems also usually rely on a pump to supply pressure , and these can sometimes fail .
    Having said the above , sprinkler systems can extinguish a small fire before it develops into a big one , with minimal damage , and can prevent extensive damage as well as saving life . Glasgow Housing Association , a few years back now , signed up to an initiative to install sprinkler systems into all their new build properties , and some older properties are having them retrofitted - there are companies who specialise in doing this .
    Dry risers are pipework built into the building : there is an external access panel to which the 70mm hose from the pumps ( fire appliances ) connects , and similar outlets on each floor . This saves the time and trouble of running fire hose from the appliances up stairwells , or dropping a rope from a window and hoisting a hose and branch ( nozzle ) up - although with tenement buildings and other multi storey buildings with just a few floors this is still done .
    The normal procedure for tackling a fire in a multi storey building , bearing in mind that the buildings are compartmentalised by design and fire is not supposed to spread from one compartment to another , is to connect the water supply to the dry risers at ground level , and then send firefighters up to form a 'bridgehead' one or two floors below the fire floor . They then connect firefighting hose to the dry riser outlets on that floor and go up one , or at most two , flights of stairs , to tackle the fire on the floor above .
    In some cases , if lifts are still operating , they can take control of them using the fireman's switch , but sometimes firefighters have to run up stairs with boxes of hose and other kit .
    The main problem with dry risers is that they suffer from sabotage and vandalism : people steal the caps , valves and other components ( for scrap metal value ) - unless they can be pressurised from the bottom , and only the outlet required to fight the fire opened , then they can be rendered useless ...
    In a 'normal' situation , where a fire is contained to a single floor , even a single flat , thanks to the design of the building , the guys will go in and tackle it .
    Unfortunately , in this instance , there has been a serious failure of fire containment and that has not been possible .
    It is laudable that BA teams went in to evacuate and rescue as many people as possible , but looking at images of that building , there are limits to where even they can go .
    8 people like this.
Share This Page
