removed
removed
removed
All these harrowing images on the news has made me a 6ft2ins male shed a tear or two also today some Fishermen 'meatheads' also admitted they too were hurting.
It's so tragic I just thought I'd let you all know that.
^ that's an appallingly written article - par for the course for the DM.
https://www.theguardian.com/uk-news...nt-against-cladding-material-used-on-grenfell
some quotes :-
"There is also uncertainty over how the project’s adherence with building regulations was scrutinised. The Royal Borough of Kensington and Chelsea, where Grenfell Tower is situated, said a “full plans decision notice was not required in this case” and that “a completion certificate was issued” instead.
According to the government’s website, a full plans decision notice is “the most thorough option”, but this was not taken. Neither the borough nor the cladding contractor, Harley, responded when asked to comment on why this route was not taken."
"During planning in 2012, the building service engineering company Max Fordham advised that one option in the refurbishment was to remove “fire stopping” systems temporarily in order to install new heating pipes. It is unclear if that approach was taken and Max Fordham did not return request for comment."
this probably refers to fire stop material in the floors and partition walls between flats and communal space.
"The cladding contractor, Harley, declined to comment on how the system was built out – citing the forthcoming investigation and public inquiry. But it is understood the design differed to that which was detailed in planning documents. Investigators are likely to want to quickly establish whether details such as cavity fire barriers, which appeared in planning drawings, were included."
One architect, who has used similar systems, said cladding panels are also available with mineral wool insulation, which are less flammable but more expensive.
“I only use the mineral wool ones because your gut tells you it is not right to wrap a building in plastic,”
This is all speculation. Wait for the report.
I'm more of a "If it looks like a duck, swims like a duck, and quacks like a duck, then it probably is a duck" man myself.
Daily Mail facts...behave.grober said:Facts bothering you?
