explorer121
Good evening,
been trying to cure a strange gurgling, syphoning noise from diesel tank. It happens when you switch on ignition and it sounds like air or a gurgling noise. Have replaced the in tank pump but the noise remains. There is no pressure from releasing the cap either. I notice behind the passenger side is another unit which I assume is the sender unit but also has two pipes rising from the top. Can anyone tell me it's purpose and function etc ?
Thanking in advance.
