MB C124 '89 230CE
Zefir15
Northampton
C124
Hi All,
Kinda new MB owner here of C124, saying Hello! :D
And by the way wanted to ask for help!
I'm in need of buying and replacing rear stabilizer bushes and bracket (as it rusted out). But can't find any in online shops in UK? Out of stock everywhere...
There is a wide selection of front bushes and brackets etc. but no rear ones (except of ebay's desp. form Latvia?).
Can anyone help please?
If it's the same one as the one used in the 300CE, it appears to interchange with a bunch of different models including some fairly new ones.
Do you have the MB part numbers for these parts? If so, I'd be happy to search.
That is the place to start in your search for replacements.
RayH
If you cant get hold of the correct bracket, the ones from a r53 mini cooper will fit.
RayH
Thank you All for reply!
I have part numbers from Polish website, but they don't ship to UK...
The bracket: 1233260926
The bush: ME-SB-14913 (not sure if it's MB parts number or MOOG?) or 1243260181
After some research, bracket should fit from SSangyoung Korando, part might be still available in Korea.
The bush is available from onlinecarparts.co.uk and should fit from CLK A208?
Thank you for help, slowly coming out of the forest... :)
These are the part #'s that you need
The clamp is probably reusable
The bushing and the rods appear to be available on pelican (Genuine and lemforder). I'm assuming that your car does not have SLS.
@alabbasi
Thank you for diagram!
I need a clamp (11) as it's rusted out and biodegraded :D
May leave rubber mounting as they are ok, but will get theo from onlinecarparts store in UK.
The rods (20) are in pretty good condition and saw them available.
